NO A/C - air pump belt
    for my buddies new to come 87' marquis, can you order a belt just to run the air pump? because, he wants to get rid of the air cond. and the car has to pass the smog test. i know that in 79'-82' A/C was a option. what to do? i hope its not a different pully system!
    hmm
    you could just ditch the air pump
    SuperFord Profile
    Support safe sigs
    -sigs should not exceed 600 pixels wide
    -sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
    -Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
    -Total sig size should not exceed 60k
    Remember, only you can prevent sig abuse....
      like i said...it has to pass the emition test/smog test/polution test...what ever you call it!
        pass the smog test, THEN dump it!
          that fucktard epi passed chicago smog on his truck (EFI) without an air pump...
            see, in this country you got to get a emmition test every two years...so this is fucked!what to do?...i need a good answer for this. its not even my car but, still.
              dont know off hand what belt to use without the ac compressor..........take a piece of twine, and wrap it around the pulleys as you think it will work, and measure.........convert inches to mm then (ie a 500k6 is 500mm in length)
                just use twine while doing the emmisions test, only needs to
                just use twine while doing the emmisions test, only needs to last a few min
                SuperFord Profile
                Support safe sigs
                  goood fucking idea!
                    Just measure it, or take the car down to a parts store and start trying belts. When I took my air pump off, I went back to the parts store three times before I got one taht fit.
                    Actually when I told them what belt I needed, the first thing they asked was if I was removing the A/C compressor. So it's not like it's an un-popular thing to do, surely they'll have a belt in stock that will fit. It just may take a few minutes.
