replacing rear brakes
    The '89 CV needs new pads on the rear. Does anyone have a walk-through on how to do it? Can't be too difficult. Although, one drum is stuck on. Is any adjustment needed when new pads are put on? I'll get the drums turned, too.
    You'll need some specialty drum brake tools, but they pay for themselves after the 1st time in DIY savings. There is an adjuster in there you will have to fool with, any manual should have the basic rundown of it, its mostly a matter of putting things back the way they came out. Lots of little springs and things to put on backwards by accident.
      What special tool? I've never used any special tools to do my rear brakes, not saying that some special tools wouldn't be worth it, but what are you talking about Pete?
        Probably a brake spoon, used to adjust the pre-tension on the brakes.
        Nick
        88 Colony Park LS
          Yeah spoon= flat blade screwdriver.
          A spring tool is nice, and the tool to remove the shoe retaining springs are nice. Not needed though. Vise grips and screwdrivers get it done.
            Damnit, you guys posted that while I was out running for parts. I got a tool for $10.
              The tools makes it much easier....
                The only one I really like to have on hand is the retainer spring tool. The others I make do with pliers and screwdrivers but getting those retainer clips out is a pain in the ass. If in doubt, take a picture first. A manual of some flavor is also a great idea as it'll have pictures and stuff. Its really not hard, just messy and annoying.
                  The hold down and return spring tools aren't necessary unless your getting paid to do drum brakes I guess, but it sure saves time and the hassle of fumbling/droppling/slipping out of place of the many springs and pins to be put back together.
                  I learned using the drum tools and I coulnt imagine doing a set without them. Spending $20 now will save hours of time on future brake jobs.
                  Ill say the same thing I told to Petely 'over there' - Ill challenge anyone to a drum brake race, me w/tools and anyone else with screwdrivers/pliers anyday bring it!
                    I had 4 wheel drums on the Bug. non-adjusting with 2 star wheels per wheel. I hate drum brakes.
                      Ok, you do your car, ill do mine.
                        I can't wait to get the rear discs on....No more drums.
