View Full Version : 92+ rear end swap
85crownHPP
03-08-2006, 01:08 AM
I keep thinking about this low mile cherry condition (minding the front end damage) 92 vic in the junkyard, and wondering why I havent pulled out the rear end to swap into the box.
The gear ratio is the same, but a 40K rear end, disc brakes and a possible aluminum driveshaft in one swoop sounds good to me. Recent motivation has come with the arrival of a shiney new 40 ton shop press at work, just waiting to be broken in. Ultimately I hope to use this press for a complete suspention rebiuld while I can.
I have a few questions and things to iron out before I attempt this, some info and details I need to work out...
first - if the driveshaft on this 92 is not a winner, will I need to swap the pinion yoke on the donor unit to mate to my driveshaft? Assuming that requires pulling the gears out, Id rather just pull the axles and do the backing plate swap to get rear disks.
second - do the rear disks have to be plumbed with the rubber lines or can they be rigged to work with only steel lines in a close to original way? If not, I could use some hints on the new plumbing to both rubber lines. Will I need to buy 92+ rear junction blocks or anything special along with the hoses?
third - anyone know if we have poly options for rear bushings? I want to do all 8 trailing arm bushings too while Im there... plus any tips on this major feat would be well appreciated! Im under the impression its a straitforward press-out press-in procedure... if you can get the bolts out.
I hope to make these plans a reality in the next couple months...
Blaze86Vic
03-08-2006, 06:47 AM
I too am about to rebuild my rear suspension, so poly bushing numbers would be greatly appreciated. And if you happen to know the front lower poly bushing numbers as well. that would be great...
DuceAnAHalf
03-08-2006, 07:44 AM
The driveshaft to axle flange should be the same for both the box and the aero.
Blaze86Vic
03-10-2006, 02:10 PM
:bump:
Paul_
03-10-2006, 02:12 PM
Pete, send a PM to Black & Flames on CVN. He's running a '93 rear end in his '89.
Lincolnmania
03-10-2006, 02:53 PM
sorry guys seem i have been missing this post......i will answer all to the best i can......come to skippyville some weekend for a seminar lol
pete the 92 rear will bolt in place.......use the box chasis rear bar
as for the brake hoses......make brackets to mount the 92 outer hoses and connect those to the single rear brake hose, or run new brakelines, one up each side of the frame......either way both lines are just being split in two form the prop valve.......the first method is alot easier
pi and towing pcg cars have a larger rear flange pete.
rear bushings are available for 92-97 from energy suspension, i believe these will work, as the control arms are the same on ours
the front bushings are also available johnnie.......92-97 set .....there is no set of just the lower front bushings......look at the bushings on your lower arms......two different sized bushings onn each lower arm is the 92-97 civi kit........you may be able to use the upper bushings in the 86 upper arms....i am not sure ........sorry for the delay.......next time just i'm me lol i hate to keep my mangs in suspense
scott
85crownHPP
03-10-2006, 03:36 PM
I went to the yard yesterday - they want TWO HUNDRED DOLLARS for any disk brake rear end!!!! Yowza. I tried to get just the aluminum pumpkin cover off it, but they made me put it back on it, lol 'Now I cant sell that rearend' they said. I guess that makes sense... I guess that means I cant nab just the backing plates and disc assemblie off of it either... Ill double check.
GOOD thing is, they told me the 98 cvp71 is soon to be parted out (in the 'dont touch' section for now) and he quoted me $15 for each 16" steelie and $90 for both spindles, hubs, and all the brake parts :nana: :nana: I nabbed some '92 upper A-arms while I was there. They came off the same 50K vic I want this rear out of, and the bushings look good as new.
DuceAnAHalf
03-10-2006, 04:21 PM
Damn Pete, come to Florida, i can get an entire rear end, minus calipers and rotors for something like $50
Blaze86Vic
03-10-2006, 04:42 PM
Well, I run greasable PI solid upper controle arms, so I need no bushings there. But thanks for the info mang!
Blaze86Vic
03-10-2006, 05:03 PM
Update: I just placed an order with Jegs. They actually had a set of front and rear Energy Suspension bushings listed for our box panthers. They mistakenly put the Grand Marq as a Lincoln, but oh well.
I will update on my install to let you all know that they are correct. For now here are the links.
EDIT, Dumbass mistake....
Fordman75
03-10-2006, 05:51 PM
I've got a question. Is the 92+ rear axle assembly any wider then the 79-91?
gadget73
03-10-2006, 07:37 PM
It shouldn't be. Uses the same offset wheels, control arms, and axles.
Fordman75
03-10-2006, 08:05 PM
So when did they widen the rears? In 98?
DuceAnAHalf
03-10-2006, 08:20 PM
2003 got the radically different width axels, hence the flat wheels they use. 98's MIGHT have a slightly different axle width. Maybe Zwack or another with a 98-02 could measure their axle width, flange to flange.
zwack88
03-11-2006, 09:28 AM
Ya I can measure my axle if you want me too.
DuceAnAHalf
03-11-2006, 09:51 AM
Dont have top do it right now, but next time you have both rear wheels off just throw a tape measure on it.:nana:
85crownHPP
03-11-2006, 08:07 PM
yeah, I figured they're asking a bit much. I guess drivetrain is the only thing this yard is expensive on, they want 500 for motors!!!
So this rearend swap is on hold for now... I might get some of those bushings for the meantime to have on hand
85crownHPP
03-14-2006, 01:15 AM
hey johnny I just just cicked the links you poasted, but when I click on 'more details' for the part listing, it lists only fox chassis cars!!!
Blaze86Vic
03-14-2006, 06:43 AM
Well, fuck
gadget73
03-14-2006, 07:35 PM
Can always do the cheater interchange method: look up the part for a panther, then look up the part for a mustang at advance or autozone and see if the numbers jive.
Blaze86Vic
03-15-2006, 07:59 AM
Jegs told me to just deny the package, that way I get a full refund. How nice of them to tell me that cool little trick.
Lincolnmania
03-15-2006, 03:24 PM
jegs and summit really suck for getting the es bushings for the panthers.......here where i go mang http://www.energysuspensionparts.com/
scott
