got tires/wheels for the Hillbilly SUV project
    I haven't gotten them mounted yet, but you can see in the pics it will be a big difference.
    A few minor updates.
    I replaced the plastic grommet for the tv cable and I now have 2nd, and 3rd gears. Overdrive has yet to be tested, but for now it will make it around town so I can borrow a friends lift to work on it.
    On a side note, if the tranny does, crap out on me, (as I halfway expect it will) I am considering putting my t/5 in this thing. With the stock engine, and lower gears I won't have to be as careful with it. I will probably just put a shift kit in my C6 and put it in the other wagon once I finally get underway with it.
    I swapped the bad wiper motor with one I saved off of my 91. Then it got a much needed tune up, with new plugs, cap, rotor, etc. It should now pass the local sherrif's inspection for out of state cars.
    Now for the pics...
    http://users.mikrotec.com/furyiii/ww...r/IM000126.JPG
    Stock pic for reference.
    http://users.mikrotec.com/furyiii/ww...r/IM000127.JPG
    My new/used ford truck spare rims,(very heavily made for some reason) in 17 x 7.5"
    (Thanks Gary!)
    http://users.mikrotec.com/furyiii/ww...r/IM000128.JPG
    265/70/17 Goodyears
    Overall the car will only raise up about 3 ro 4 inches, but it should give me the extra ground clearance I am looking for.
    Axle codes
    Open/Lock/Ratio #
    G / H / 2.26
    B / C / 2.47
    8 / M / 2.73
    7 / - / 3.07
    Y / Z / 3.08
    4 / D / 3.42
    F / R / 3.45
    5 / E / 3.27
    6 / W / 3.73
    2 / K / 3.55
    A / - / 3.63
    J / - / 3.85
    Sounds like a fun project
    Freebies are good!!
      I always liked those spare wheels...
      How you plan on runnin' truck wheels? IIRC, those only fit '97+
      '95 Ford Bronco XL -
      sigpic :rebel:
        I am going to have to either drill them to 5X4.5" lug spacing, or else I am going to try to find some adapters. In any case I need spacers, due to these having 3/4" less backspacing, than a stock vic wheel. In the end it will probably be better to get 1" + spacers and turn them down if needed.
        Axle codes
        Open/Lock/Ratio #
        G / H / 2.26
        B / C / 2.47
        8 / M / 2.73
        7 / - / 3.07
        Y / Z / 3.08
        4 / D / 3.42
        F / R / 3.45
        5 / E / 3.27
        6 / W / 3.73
        2 / K / 3.55
        A / - / 3.63
        J / - / 3.85
          Time to bust out the BFH to mount the tires. Those should lift it up some.
          1989 Grand Marquis LS
            They should raise it up 2.5" but I will be working on the springs as well so it will probably gain another inch or trhee from that as well.
            I would like to see 4-6 inches overall. that will make it much nicer to work on, if I have to swap out that tranny.
            Axle codes
            Open/Lock/Ratio #
            G / H / 2.26
            B / C / 2.47
            8 / M / 2.73
            7 / - / 3.07
            Y / Z / 3.08
            4 / D / 3.42
            F / R / 3.45
            5 / E / 3.27
            6 / W / 3.73
            2 / K / 3.55
            A / - / 3.63
            J / - / 3.85
