Compression #'s for a 4.6
    Ok when it warms up I'm going to get a compression tester and check to see how the vic is doing in this area. What is the PSI per cylinder I should have?
    Thanks,
    Zack
    I use to know this!
    Do it with a 5spd!
      There is no set number to look for, just make sure that the lowest cylinder is within 75% of the highest.
      For reference.
      Linky...
      -Michael
        Ok thanks.
          No problem.
          -Michael
            IIRC 120-170 ish but all should be within 25%, If one wasnt you would feel a miss type engine feeling.
              So what did you get? I am curious to know because I have my compression numbers now as well. Mine were all about 162-168psi.
                Haven't done it yet. It is starting to get nice again so it is time I do it.
                  Remember to record them and then you can go back and see how much wear you are getting. 160's is pretty damn good.
