I posted this on CVN and only got two replys. I have a friend that has A set of Eibach springs front and back for an SS IMPALA.I know the front will fit there 5.5 " wide.Alittle lower than the wangon springs I got from the parts store. Will the rear springs fit??Before I tear everthing down and find out the hard way...Tanks.. LIVE LONG AND PROSSPER\\//'
Springs
Springs
91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpicTags: None
The rear springs on a panther are double pig tail springs. I am not sure what the IMPSS use, but I would imagine that it may be the same. DuceAnAHalf has converted his rear springs already to racing coils. I am also about to convert my rear to coil over shock design. Front springs are readily available in many different rates from 500lbs/in to 1500lbs/in+ (Ride hight will vary) Our rear springs a little less common, but also availabel from 95lbs/in (stock vililian) to 400lbs/in (again ride height will vary). The downside is that the ride height will vary and you can not adjust it. Converting as Duce has and I will will allow at least the rear to be adjusted.
Yeah about those coil-over springs. Apparently Ford decided that the rear spring perches dont have to line up. the upp perch is a good 3 inches further forward than the lower. this puts the 2.5" spring at a bad angle. so i dont have then on yet. I had to move the tube foreard and have to have a snap ring cut into it.http://secondhandracing.com/Home.aspx
No I 'm not offended; just have'nt learned my way around here yet. The front springs are beefy as hell so I thinks they will ride nice as for the back wil see when I pull the old ones of..Thanks gent for your help..:2thumbs:91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpic
