DOHC heads
    DOHC heads
    Ive been wanting to do a dohc head conversion on my sohc 4.6...I was wondering if this was possible
    R.I.P Linsey Nelson
    Originally posted by MeanVic84
    Chocolate Rain. Some stay dry and others feel the pain.
    Not without major modifications. You'd need the heads, cams, gears, timing chain, timing chain cover, pistons, etc. You'd be better off getting a used DOHC off of eBay.
    2000 GM LS w/HPP
    K&N FIPK
    Dual Flowmaster 50-series SUV mufflers
    3 & 1/2" rolled, angle cut, polished stainless steel tips
    70mm throttle body from a 5.4L Econoline
    2003 Leather seats with rear cupholder
    2003 Steering wheel w/redundant radio controls
    ADR Spartan triple chrome rims size 19x8.5"
    Falken FK-452 245/40/19 tires
      It's possible, but like he said, you'd be better to swap the whole motor... and I'd say stick with the 2v- it's better for low end torque and with that big of a car, torque is your friend.
        Also, it won't fit unless it is an 03 or newer model.
          Oh don't say that. With enough work anything can be made to fit. Probably would be cheaper and easier to swap the whole motor tho. I'd prolly pick up a wrecked Mark VIII or something to gut the engine from.
            :stupid:
            Anything is possible with a mig welder.
              This Marauder motor was slammed into a 1993 Crown Vic. It was later sold on eBay when the car was totalled...
                  Don't forget all the Bondurant cars...all cobra powered. With 6 speeds. YOu can buy the whole engine/trans assembly NEW from ford for like 5-6K, which is a hell of a deal.
                    Notice in the picture how the engine should be hitting the wiper box corner. This is why a 4v engine will not fit on a pre 03 vic. The wiper clearance issue. Who needs wipers with rain X anyway?
                      I just noticed...how the hell do you put a 4v in a 93? Install the whole wiring harness also? Thats the only way to do it right, EEC IV vs EEC V. Not exactly just a motor swap.
                        A 93-94 Mark VIII EEC IV could probably run that motor
                        2004 Marauder M79 90K miles Jmod!! 14.85 @95.63
                        2004 Crown Vic LX 135K Silver Birch Light flint leather FMX1 04 P-71 PCM swap 04 P-71 Airbox and Zip tube "$100 MZT" 01 F-250 70 MM TB 21mm swaybar wood steering wheel BH headlight relay
                          It sure could.
                            But you would only get the 280 vs the 300 hp.....?
                              285-295; depending on intake; a cam change will take care of the rest...
