View Full Version : Front & Rear Spring Pics?
nitroracer
04-06-2006, 12:12 PM
Does anyone have a picture of the front and rear springs on a box or aero car? Im thinking about cutting half a coil to drop the car and inch and firm up the ride a bit.
Enigma
04-06-2006, 12:18 PM
not on the rears, you won't. Pigtails on both ends. I just got my new rears this week. :)
I've heard rumor that on the fronts you can cut, though.
nitroracer
04-06-2006, 12:25 PM
It was worth a shot, I remembered hearing the rears are double pigtail but I had no clue what it meant. Now it makes sense.
Enigma
04-06-2006, 12:36 PM
I've also heard rumor that you can swap in Chevelle springs, and they come in all sorts of different heights and spring rates.
Can anyone out there confirm this.?
Blaze86Vic
04-06-2006, 01:11 PM
You can get these to drop the ride a bit and firm it up in the rear. It would be a direct replacement, and you have some choices on spring rate. I believe they are a little shorter than normal ones, so getting a 200lb or 225lb will lower the rear as well as firm it up. Once those are in you can cut as much as nedded to match the front ride height.
Linky (http://www.speedwaymotors.com/xq/aspx/paging.yes/dept_id.158/display_id.168/qx/Product.htm)
nitroracer
04-06-2006, 01:17 PM
Hrmmm, I can test out that chevelle spring idea if I have the time this summer. Now that I have a 71' Malibu... They would be stock 35 year old springs, but it would confirm if they are the same or not.
Blaze86Vic
04-06-2006, 02:17 PM
You could just measure the diameter of the upper and lower perch, and compare that to the upper and lower perch of the Merq.
DuceAnAHalf
04-06-2006, 05:27 PM
Please do. im not sure if the aftermarket springs for our cars are the same as a Chevelle. The magazine that has them shows the general spring selection choices for both a Chevelle and a Camaro.
