AOD valve body interchangablilty
    They are pretty much swappable, right? I want to pull the VB with shift kit out of the old 87 trans and put it in my spare trans out of my 89 sedan...
    I don't see why it wouldn't...
      Yes they are. There are only minor differences, but they are all interchangable to my knowledgs. I have whitnessed some of the differeces in the VB between the PI shift patter and the stock shit patter. But if you keep the VB all together it's not a problem.
        All my transmissions have the same pattern...All I plan on doing is taking the VB apart and cleaning it. The trans it came out of had a pretty catastrohpic failure....but the wasted trans has the shift kit, A servo, and HO governor. (all of which I will be swapping)
          Be very carefull when cleaning it, and be in a very clean area. CLEAN CLEAN CLEAN CLEAN CLEAN!!!!
