amp on stock alt. question
    hey mangs i want to run a smallish 300watt max power amp to my 2 rear 6X9's on the stock electrical system. I will be bypassing the old amp with a harness and using new better wire for the speakers. Can I do this on the stock alternator?
    Sure. Should be fine, just use heavy enough cable to the trunk and fuse it.
    --gadget73
      I did some calculating a while back and concluded you could clear running up to 400 watts RMS off our stock alternators using a class A or B amp, and 600 watts RMS with a class D amp.
