i just put new bushings in a new control arm for my coupe because, i broke the old one and i want to know what kinda grade of bolt to use? because, the old ones are junk.
lower control arm
is it a good idea to reuse the old bolts?(they are original from 81')
if they look good you could prolly get away with it, but if they have signifigant rust, any warping or thread damage, fogetaboutit!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
i would replace the bolts if they are in bad shape........you can harvest some bolts from any 96 and older panther chassis, if you are unable to find new ones........go with a min of a grade 5 bolt
scott
i jus replaced the control arm and spindle(cuz the bering blew up on me) and the control arm bolts were like new, they jus slid out! undercoating ur car is a great i dea!...now its in tip top shape again!
