Do we have a complete panther radio system install?
Radio swap
Radio swap
1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
SupermotorsTags: None
http://www.crutchfield.com/S-fojyUe5...*ctzfubflFYgzy
There you go. I looked they have them for your car but I don't know which sound system your car came with stock. Just fill it out and they got the wiring harnesses and dash kits.2000 Mustang GT "Blondie", 2000 CVPI "Sargent Crusty"
what do you need to know i can get it alljay--1983 towncar, 302v8 cfi, dual straight pipes w/resonators ,edelbrock motor goodies, custom interior, full custom stereo system, full rebuilt trunk audio setup, custom paint...more to come......
yeah, you can put together everything you needPete ::::>>> resident LED addict and CFI defector LED bulb replacements
i just finished putting in a Sony CD player in my lincoln, it was pretty simple after you get the harnessess wired up, It sounds awesome too but I need new speakers, im running the stockers right now, lol.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
I was thinking for a later time wheneverythign else was done. The radio is on the sucky side. I just wanted to redo everything so that it sounded good and I could run a decent wattage threw. New deck and speakers. Maybe a sub. Honestly the stereo in the 00 Merc we have is good enough.1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
