The best handling combo?
    What is the best way to get the best handling out of my GM?
    The Terror Of The Streets
    http://www.cardomain.com/ride/2299944
    Right now when i take corners it likes to float to the outside of turns.
      get a police rear sway bar and a bigger front one if you dont already have a 1 1/8 up front. Then get some good shocks and it will be much improved. you can get stiffer springs too if you want to go that far.
        I want to go all the way, I am hoping to get my GM to hold the road like my old 99 cougar would.
          Well, time for QA1 shocks, coild over shock conversion for the rear, and 1000lb+ springs for the front, bigger sway bars than are available (ie custom needed), and strip interior and all other non essential parts. Catching this thing up to a compact sports car is going to take a whole lot.
            dont forget to ditch the un parallel 4-bar rear suspension set up. go for either a 3-link set up or a IRS. Also a cage will help to stiffen the frame.
              Can't break the laws of physics. You can get that car to handle surprisingly well for a 2 ton luxo barge without a whole lot of money, but it would take a lot of work and $$$ to make it handle as well as a car half it's weight.
              My first suggestion would be to take a look at your front sway bar. Measure the diameter of it and let us know what you have. If it is respectable then a set of the poly bushings and end links would do a lot for body roll up front.
              Better shocks will also make for an improvement.
              The Grand Marquis have softer springs than a standard crown vic. I would swap in a stiffer set of springs as well.
              Tires are also a factor, I would suggest 16" wheels and some sticky tires with a stiff sidewall for better handling as well.
              Then there is the previously mentioned rear sway bar from a cop car.
              If you get through all that, then the car will be world's apart from the way it handles now.
              BTW, if you swap out your springs, I might be iterested in your old ones from the front, assuming the car isn't sagging.
              Bryan
              Axle codes
              Open/Lock/Ratio #
              G / H / 2.26
              B / C / 2.47
              8 / M / 2.73
              7 / - / 3.07
              Y / Z / 3.08
              4 / D / 3.42
              F / R / 3.45
              5 / E / 3.27
              6 / W / 3.73
              2 / K / 3.55
              A / - / 3.63
              J / - / 3.85
                Just upgrade the springs, shocks and put a PI rear bar on it...Bigger front bar makes for more oversteer. Poly bushings throughout. And low profile tires make a big difference also.
                  I am going to replace the front springs for sure and you are more than welcome to them, i dont need anymore "spare parts" laying around. The city is already all over me to get rid of what i have.
                    Your car looks familiar, but I don't think I've ever seen a GM in that color.
                    '90 Mercury Grand Marquis GS
                    5.4L swap coming soon.
                      Hey, could you measure from center of the wheel to the top of the fender opening on the front fenders?
                      I can figure out whether your springs are taller than mine, from that.
                      Axle codes
                      Open/Lock/Ratio #
                      G / H / 2.26
                      B / C / 2.47
                      8 / M / 2.73
                      7 / - / 3.07
                      Y / Z / 3.08
                      4 / D / 3.42
                      F / R / 3.45
                      5 / E / 3.27
                      6 / W / 3.73
                      2 / K / 3.55
                      A / - / 3.63
                      J / - / 3.85
                        Not a problem ill do it tommrow and post it.
                        N A - Mine is a year older than yours but the same model, i thought your was the same color.
                          Have you checked out what GMGT has done to his car? http://www.grandmarq.net/vb/showthread.php?t=939 There is the link to his suspention mods. If I had a box I would probably do that cause it seems like you would get good performance for not a horrible amount of cash.
                            make sure the front suspension and steering components are tight with no play
                              im pretty sure my ball joints are going
