anyone install a TC trunk lid pulldown in a non TC???
    Did box TC's even had these?
    Im brainstorming more upgrade ideas. Plus ever since I got some good used weatherstrip for the trunk its been hard to close, lol.
    Auto trunk close? Yea boxes had that.
    '95 Ford Bronco XL -
    sigpic :rebel:
      Trunk stuffer, eh?
        Scott made it work with his. But his is also a t/c
          Box townies had it optional. The Sig and Cartiers had it. My base model doesn't. If the latch design is the same, and you can mount the motor at the right height, I don't see why you couldn't do it. Would need to figure the wiring, and there is a switch in the upper latch part that you'll need.
            hhmmm - I was wondering if the switch was in the top or the bottom... Im betting the latch in the trunk lid will be a little different, if nothing else in how it mounts. Maybe i can swap just the switch in the upper part, or rig my own somehow.
            I got a good look at one in an newer TC the other day and it looks like that catch/motor assembly would bolt in place of an ordinary one, so hopefully it will be simillar for boxes.
            Hopefully Ill get to the yard on tuesday to check it out
              Hrmmm, who thinks I could rig something up for a wagon?
              Nick
              88 Colony Park LS
                that I would like to see!
                  I'll add it to my list of things I wish to be able to do.
                  Nick
                  88 Colony Park LS
                    Hi 85CrownHPP
                    The pull down motor has a two switches built into it and there is another switch on the catch mechanism, I would have thought a pull down motor from a box Town Car would bolt straight into a Crown Vic.
                    Wiring is straight forward enough.
                    Regards
                    Dereck
                    President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
                      I would buy one.... Mine takes a good heavy swing to latch.
                      2000 Grand Marquis LS
                      Mercury Owners Group member
                        For the wagons, you might be able to modify something off a newer mini-van that has the rear hatch pop open and shut.
                        Save a seal, club a liberal.
                          I need a new striker pin, with a busing on it, for my tailgate. Could use some hinge pins too, or whatever makes play in it.
                          sigpic :rebel:
                            Mine too, gunna replace the hinge pins and strikers and see if that does anything for it.
                            Nick
                            88 Colony Park LS
                              If those plastic bushings aren't on the strikers it wont work right. I sprayed down the non functional latch on David's SuperLinc with carb cleaner to get all the goop out, the re-lubricated with fresh spray lithium grease. Between that and a new striker the door works perfectly again. It wouldn't even latch before.
