View Full Version : To trac loc or not
Datdambear
04-27-2006, 11:37 AM
Ok guys are the ford trac loc good or would an after market eaton or detroit be better....I keep being told that the ford trac loc sucks...I can pick one up cheaper than the eaton or detroit...I want to do this once ....not twice...
mrltd
04-27-2006, 12:48 PM
eaton is basically the same as the stocker. Torsens are great but cost more than my car...detroit is clunky and loud. The true tracs might be alright. No experience with them.
87_crown_vic
04-27-2006, 01:10 PM
i have a 2.71 trac lock in my white '87. i have had no problems w/ it except when a friend borrowed it and got a flat. they had a diff tire size put on and it started acting up. i had a tire that matched the other side put on and no more problems. i have changed the diff. oil twice and all the teeth look great. i live on a gravel road and fight some good snows w/ the car and it hasnt let me down.
Blaze86Vic
04-27-2006, 01:43 PM
Yeah, I have one of the TrueTracs that mrltd mentioned. They are maintainance free, top notch performance, no noise wat so ever, and does not creat any adverse driving characteristics. However, the down side is they are pretty expensive. A little bit over $400 for just the differential.
"I have a 2.71 trac lock in my white '87...".
Do you mean a 2.73 gearset?
87_crown_vic
05-08-2006, 12:21 AM
from the code on the metal plate on the rearend it is a 2.71
gadget73
05-08-2006, 01:17 AM
Whats the code? Not sure there was ever a 2.71, 2.73 was standard on many cars though.
boXman
05-08-2006, 01:38 AM
No 2.71 that I've ever heard of. Get the AX code on the door sticker.
Datdambear
05-08-2006, 10:00 AM
Thanks guys I am getting a set of 410s and trac lock from Hwy cruiser I can not wait....:wootrock:
Grand Marquis GT
05-08-2006, 10:21 AM
Ah, so YOU got em! :mad:
Aha! It's all good mang...
Jason91GM
05-08-2006, 08:20 PM
i was having fun wth my trac loc a few minutes ago, in a parking lot. ooohhh yea
HwyCruiser
05-08-2006, 09:30 PM
You may want to look at replacing the clutch pack on the trac-lock. It's not 100% dead, but it's seen better days. Can anybody help him out on how difficult a job this would be?
DuceAnAHalf
05-08-2006, 09:34 PM
If it is out of the axle it is not a big pain, just getting it in the diff while keeping all the friction and steels together is a little tricky.
Datdambear
05-08-2006, 10:59 PM
Yep...I got a rebuild kit already setting here.I have a buddy who is going to rebuild the unit for me. Then I will install it one night after work..Zooom Zooommm:wootrock:
sdacbob
05-17-2006, 12:58 AM
If you run 4.10's you'll probably need the extended tailshaft and driveshaft from a P71 or you might get serious vibration issues, ect at higher speeds. Safety concerns too. Panthers have very long driveshafts that tend to vibrate at higher speeds. Anything more than 3.55's usually requires it
Grand Marquis GT
05-17-2006, 06:27 AM
I also hear that forced tailshaft lube mod is good too...
turbo2256b
05-18-2006, 12:00 AM
I like the Auburn lockers and they have a new one that is way better than the old ones
