Brake time!
    Brake time!
    Before the car will pass inspection I need rotors and pads in front. It's been awhile since I've had to buy this stuff. I know rotors come as one. When I do the pads, does one box cover both sides? And am I going to have to buy shims? If so does one kit do both sides, or just one? Secondly, I figure since the rotors are coming off, might as well replace the wheel bearings. Rockauto lists an inner and an outer. Am I correct in assuming that I have to get one of each for each side? Thanks!
    Save a seal, club a liberal.
    As far as I know the pads are sold as axle sets. So you should be getting enough pads that will replace the entire front set or rear set.
    2001 Grand Marquis LS
    SuperMotors Page
    CJMF
    Motorsports North East
    Best 1/4 Mile : 15.771 @ 86.96 mph 11/05/05
    224 RWHP - 250 RWTQ - 03-18-06
    New Best 1/4 Mile :
    15.195 @ 89.79 mph 2.207 60' 11/03/06 - Race weight 4458 lbs.
      yup, and as for your bearings, yeah, sold individually, youll need 2 of each
        No need to buy shims.
          That covers everything. Thanks guys!
            no need to buy bearings unless bad, buy two brake rotors, a set of brake pads (both axles, 4 pads) and two grease seals....also get a tub of wheel bearing grease and a can of 2+2 carb cleaner (fuck brake clean it sucks) packthe bearings,put some grease in the new rotors (a scoop from your fingers is good, wanna cover the new races with grease,and cover the area good,making sure no dirt or grit is present...........easy job, make sure to workin the shade, drink lots of soda
              o well guelss i was too late
                I'll double check on the bearings. If I can save some money by not having to do them, thats even better.
                  I agree with all above, except teh soda.
                  that shit dehydrates you. Drink water or gatorade!
                    :stupid:
                    Soda is tar with a couple drops of salt water. Drink water, tea, any kind of sport drink.
                      Don't forget the grease seals for the new rotors.
                      --edit
                      ok, scott did mention grease seals. my bad.
