The hillbilly SUV is riding high at last!
    I posted some mock up pics a while back, but here is the real deal. I parked it next to my other wagon to give an idea of the height difference.
    I may go 1/2" to 1" shorter on the front tires just so I can get a little better turning radius but for now it works just fine.
    It still handles surprisingly well, but considering it has new shocks, sway bar links and bushings it probably makes sense, that handling doesn't feel much different.
    It now clears parking stops with ease, and I am goin to drive it across salt river (only about 8" deep at the crossing) later. I'll get a few pics just for fun... if I can get anyone else to ride with me long enough to take them. LOL!
    P.S. when you install a spring lift, make sure the spring seats completely. I missed one and it popped the rest of the way down into the lift while going around a curve at 50mph. It didn't effect handling or move the car much at all. I however nearly ruined a perfectly good pair of underwear, when I heard this loud "SPROING!!!" up front and felt the steering wheel and floor vibrate for a second or two.
    Axle codes
    Open/Lock/Ratio #
    G / H / 2.26
    B / C / 2.47
    8 / M / 2.73
    7 / - / 3.07
    Y / Z / 3.08
    4 / D / 3.42
    F / R / 3.45
    5 / E / 3.27
    6 / W / 3.73
    2 / K / 3.55
    A / - / 3.63
    J / - / 3.85
    Nice!!!
      damn man that thing is sitting high and mighty!
        I'd like to do that with a wagon and install a front axle while I'm at it.
          Freshmeat, that would be a lot of work.
          After fooling around with the front suspension for many more hours than I would like to think about. I would suggest getting a matching set of front and rear axles off of a 4x4 with leaf springs.
          You would need to completely disassemble all the front suspension, and grind the mounting brackets off that go to the lower control arm. The pumpkin on the front axle would make contact with the crossmember under the oil pan if you werent very careful. The car would have to sit pretty high and or the crossmember would have to be clearanced. Then there is the issue of steering, brakes, and shock mounts. Not to mention a transfer case and axles.
          I am not saying it is impossible but it would be a LOT of work.
          The rear would require some fabrication, but would be a piece of cake compared to the front.
          IMHO it would be simpler to set the wagon on a truck frame that already has a divorced transfer case, shafts and axles. Sure, you might have to shorten it, a bit but since it would be welded onto the car's existing frame anyway, it would definately be plenty strong.
          if you go this route, your only concerns would be how to weld everything together, brakes, and steering.
          The only drawback would be the extra weight. It would be a bit heavy for any serious off roading, but it would definately be mega fun!
          Axle codes
          Open/Lock/Ratio #
          G / H / 2.26
          B / C / 2.47
          8 / M / 2.73
          7 / - / 3.07
          Y / Z / 3.08
          4 / D / 3.42
          F / R / 3.45
          5 / E / 3.27
          6 / W / 3.73
          2 / K / 3.55
          A / - / 3.63
          J / - / 3.85
            Looks good! You have a purpose to have it that high. Those fags with the 24's that jack up cars to fit them under them should be shot.
              Samaritan- I'm aware of the work involved... I've helped build 4x4 vehicles before, including researching/examining solid front axle swaps onto Explorers and Expeditions, which requires basically the same work.
                lookin good bryan
                  Thanks guys!
                  FM, sounds like you are all set. Except for time and money that is.
                  Axle codes
                  Open/Lock/Ratio #
                  G / H / 2.26
                  B / C / 2.47
                  8 / M / 2.73
                  7 / - / 3.07
                  Y / Z / 3.08
                  4 / D / 3.42
                  F / R / 3.45
                  5 / E / 3.27
                  6 / W / 3.73
                  2 / K / 3.55
                  A / - / 3.63
                  J / - / 3.85
                    Samaritan- you're right. It's gonna be a LOT of work, but I'm looking forward to it. I actually plan to ditch the primary crossmember for a hand-built piece I've been trying to design for Jeep 302 swaps.
                    To be honest with you, the challenge is why I want to do it. Wouldn't be very practical, but hey- it'd be a blast to drive to the trials and whatnot. Still gotta get my wagon fixed, get this Mustang going, swap the engine from the wagon to the Mustang, build the new engine for the wagon, add a :mumble: to that engine, build another new engine for the wagon...
                    It might be a while.
                      I like it! Though, for some odd reason, the silver car looks much wider now compared to the other one.
                      Save a seal, club a liberal.
                        Now Im gonna have to buy me some of those. Looks good. Damn good.
                        1989 Grand Marquis LS
                          mmmmmmmmm tall
                            I think it has to do with the angle of the shot. I had to back around another vehicle so I had the blue one parked at an angle. It just so happens that when I snapped the shot, it was dead on with the blue one and at an angle to the silver one.
                            Axle codes
                            Open/Lock/Ratio #
                            G / H / 2.26
                            B / C / 2.47
                            8 / M / 2.73
                            7 / - / 3.07
                            Y / Z / 3.08
                            4 / D / 3.42
                            F / R / 3.45
                            5 / E / 3.27
                            6 / W / 3.73
                            2 / K / 3.55
                            A / - / 3.63
                            J / - / 3.85
                              What are you using to get the extra height, those poly spring spacer things?
                              When I did the front suspension on my car, one of the springs slammed home as I was jacking the lower control arm up to get the spindle re-attached. That bang scared the crap out of me, so I know what you mean about making sure they're seated fully lol.
