suspension upgrades for a town car?
    OK I don't know much about the panther suspension setup, all I know is mine is totally origional from 1989 and its all in good shape (says AAA car care) what are some minor upgrades to make this lincoln turn better??
    Police sway bars ($75 or less) - flatter cornering
    New stock or heavy duty coil springs ($150 or less) - stiffer spring rates, restores ride height
    Bushings/Ball Joints ($100ish) - Removes slop from all moving joints
    -Matt
      Again, Nitro is right...though need to add one thing and specify another.
      Get heavy duty poly endlinks for the front and get the police rear bar ONLY. Unless you have some insanely small front bar. The front upgrade isn't really that necessary.
        big brakes........then you can use the 98-02 pi swaybar up front, and the es front bushings.......also the 99-02 pi steering box........skippy called gadgets car "nascar steering" lol
        still working on getting poly bushings for the rear
          Yeah, definitely poly endlinks and frame bushings for the bar. Cheap and easy. I'm actually considering replacing my front bar with a smaller one to see what it feels like. The big front bar helps a lot when you have crappy worn out suspension but if its in decent shape it shouldn't matter that much. It helped my car when it had old suspension but now I think its actually too much.
            I want a NASCAR box
