trwp72
12-15-2004, 05:42 AM
Ok, everytime it gets cold here, (below 45 degrees) My '91 CV with a 5.0 starts acting up... from the time I start it, until it warms up.. it has like a dead miss, intermitently... It is almost like someone pulling the coil wire off and putting it right back on, before the car quits... Also the check engine light comes on once, for about 5 seconds, then goes off...only code it shows is the egr valve has no flow... it is really annoying.... The car has had replaced...
Distributor cap
rotor button
wires
plugs
gas filter
I was thinking maybe the coil, pick up, or ignition module was acting up.... Any thoughts????
Tom...
Distributor cap
rotor button
wires
plugs
gas filter
Tom...
