DOA AOD
    DOA AOD
    Cruising down the highway last night, and my car started chugging. I thought that it was the engine. I shifted down to Drive and it straightened out. I shifted back into OD, and everything seemed fine until I could hear the engine over my radio. The RPM's were slowly climbing and the car was slowing.
    I pulled over and checked everything out, finding no obvious problems until I smelled the fluid. The nastiest smelling red tranny fluid I had ever smelled.
    This just brings up my time line for my conversion a couple of months.
    I am going to tear the AOD down and see if it is salvagable. By the looks of it, it had been rebuilt once already. Until I find evidence otherwise, I am going to blame it on the retarded valve body just because I can. That is definitely going into the dumpster.
    1st gear lockout.............just retarded. :chainsaw:
    that sucks is this on your 81? if it is i would get a newer core aod to rebuild
    scott
      someone else has an 81 marquis too?
        My wide ratio kit instructions said the 89-up trannys were the better ones to use...
        '80 Town Coupé
          Dear Gurus,
          Don't know if this is useful or not. I've an '89 colony park. Last fall the day before I was to drive 26 hrs to Sturgis Sd, I heard a horrible noise. My transmission guy said it was the OD but that that tranny had been built originally w/o od but the weight of the
          car blew the od ring every 40 k or so. He thought I could drive it with the other gears which I did - 26 hrs each way. Gas mileage was only 17 and I sweated but I got home w/o OD. Donald McCaig
            I have a 91 P72.
            I have used 90/91 trannys and a couple of cores in that vintage also.
            I am going to open this one up first and see what it needs besides a new OD band.
            I will be putting one of my Mustang valve bodies and governors in it with a higher stall converter.
