good alternator to upgrade to
    I know my lincoln has had 3 alternators and 1 caught on fire, lol. This is all before I got the car though. What is a good alternator to upgrade while I'm doing my electric fan upgrade?
    3G alternator from a 94-95 Mustang they are also found in other ford models
    The Best
      yup, what he said. Also, pull apart that harness from the alternator to the fender, and see if those wires aren't melted. Lots of them fry under the split loom tube.
        i'm gonna start trashing all factory altenator harnesses........most are in horrid shape
          I might remove mine too and just replace that fuse block with a 150 amp breaker. It would also clean up the wiring a little bit, which I sure do need. The spaghetti looks pretty crappy.
            Bolt in a 3G alternator.
            '90 Mercury Grand Marquis GS
            5.4L swap coming soon.
              That 3G alternator can also be found in both 3.0 and 3.8 Turuses, but they both come in small and large frame setup depending on year of production. Look for a small-frame 3G alternator, it's recognizable by having a very short ear for the top bolt (as opposed to the large-frame alternator that has the hole for that bolt about an inch further away from the case).
                I got my 3G out of a Windstar van.
                  Any Taurus with that engine? how about a '93 Taurus???
                    is the 3g compatible with the alternator plugs on some panthers. i noticed the alternator on the waggin i sold Zack had a different type of alternator. it had a nut that held a wire on, whereas mine are the simple plugs. just asking, since i am in need of upgrading my alternator.
                    Addicted to 86-87 Panthers
                      93 Taurus you say? hhmmmm
                        yeah a '93 with a 3.0
                          Run 4 gauge or bigger directly to the battery from the alternator. Make sure if you are to do this you upgrade the ground on your battery to frame and ground from chassis to engine. I upgraded mine to 1/0, I have top/side post battery and I use both terminals.
                          Welding Supply ---
                          4 gauge or bigger from there, you can even get red cable for the positive and black for the ground if you would like. Get some ring terminals from there too. You can crimp the ring terminals with a vice, or you can spend another $7 and get a swedge crimping tool from that site. Cutting thick ass cable, use a hacksaw unless you got some good cable cutters. Which will make it look nice and clean for the wiring to the alt. Get some split loom, or a heat shield sleeve for the wire to protect it. Get some heat shrink too, it's cheap and if you have a hair dryer or heat gun you can shrink it. You can crimp the cable with a vice.
                          JC Whitney ---
                          If you need a cheap & nice looking battery terminal to connect the new cable to.
                          --List of Needed Items--
                          1. [10-15ft] 4AWG or Larger
                          2. [x6]Ring Terminals
                          3. [x1]Battery Terminal
                          4. Heat Shrink Tubing
                          5. Split loom or something to protect the wire.
                          6. Fuse Holder & Fuse
                          If you get the 3G Alternator your factory cables will not work to well with the alternator being 130amps. The factory cables, I believe [at least in my '81] were 8 gauge which is almost dangerous to use with that high of amperage. That is why a cable upgrade is needed.
                            Thanks very much. I'll keep that in mind when I do do the upgrade. When you say to upgrade the grounds, do you mean to re-do the grounds?
                              I would ground to the exact same places, just clean the areas off with a wire brush or something of that sort. You can run new cable and get rid of your old, or you can leave your existing ground. Current will take the path of least resistance for the ground. I got rid of my ground cables so I could see how long I had to make the new ones. I just ran a new one to the alt for the positive.
