it was -35C outside and i went to start up the old mans 88 colony park...but it would not start! it sounded like it wanted to but, no go.i got out a heat gun because, i thought the fuel line froze but, no go. i hooked up my scanner to do a key off test. one code came up for the intake temp sensor...i put the heat gun to it for 15 min...and brum! it started up. has this happened to anybody else?
sensors
yea coolant temp sensors like to crap out in cold weather. i've replaced a bunch over the years.....have tried the heat gun methed also lol
scott
sensors...
Where is the coolant sensor? and the intake temp sensor? Or is this the same sensor... This may be the problem with my car "hickupping" when it is cold....
the coolant temp sensor is located on the lower intake towards the front passenger side
the air temp charge sensor is located about center on the drivers side lower intake, you will also find the sender for the temp gauge on the drivers side of the lower intake
scott
sending units....
Lincolnmania...
Thanks for the info....
