killing a gauge
    killing a gauge
    Dear Gurus,
    Some months ago, the engine light in my 89 colony park came on and I quickly added water and replaced a radiator hose. Recently the check engine light has been coming on, intermittently. My mechanic checked the car: nothing wrong. The engine light can be in full glow - until I put the car in neutral and restart.
    So it's a bad gauge, I'm thinking probably the temp sensor. No big problem, a good excuse to get oil & temp guages mounted on the A-pillar.
    Howsomever: I'm going to spend my New Year's eve in Ohio at a sheepdog trial with four dogs. It's a nine hour shot. Weather, country roads are unpredictable and I've limited slip and good chains. But the last thing I need is a red engine light glowing at me and making me wonder - did the mechanic really do his job?
    I'm no guru. Last engine I rebuilt was a 51 Powerwagon. But is there some fuse I can pull, some wire I can cut that'll make the damn thing go dead until I get the new gauges?
    Donald McCaig
    donald
    if i were you i would promptly get a set of gauges installed before your trip......nothing more aggravatind than staring at an idiot light, they come on when it's too late most of the time lol
    get the gauges installed before your trip and monitor oil pressure and coolant tempatures
    scott
      you can take apart the dash, remove the speedo, and take out the check engine light bulb... but Id only do that after you install the gauges.
