will a 90 CV auto trans work and be a direct bolt in, in a 87 CV auto???
TRANSMISSION ...
yeshttp://secondhandracing.com/Home.aspx
Most people don't know how to adjust the TV cable properly. You'll hurt your AOD within a mile or two if the pressure isn't set correctly.
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
tv cable adjustments aren't that hard. Just adjust it per those directions and you'll be fine. Mine is set to be just slightly less than full pressure at WOT and its about perfect. If I adjust it tighter, it doesn't want to shift.86 Lincoln Town Car (Galactica).
