Springs are in!
    Springs are in!
    Yep, I got the front end done today - installed new rotors with bearings, and since was stripping the thing down to bare spindles I figured it'll be a good time to throw some higher-rate coils there. I ended up getting 5.5x12.5" ones, wire diameter is 0.8" and the inside diameter of the coil is 4". Rated at 1050lbs/in, made by TRW, cost $65, part No. CS7172 at Advance Auto, can be found in the paper catalog only! Took me forever to do the swap, and now that I'm done I can't even go for a test-drive cause I have no shocks in the front now (had to break the old ones off cause the springs wouldn't go out while they were still attached to the frame). I think I'll be getting the KYB-GR2 for cop cars, but it all depends on price and availability...
    Oh yeah, the pics - you saw Blaze's car with the new springs, well that's how my car looked like with the stock ones. Now with the new ones she sits just about the same,.
      good deal! sounds like you've been busy! let me know how the springs feel mang
        The rate in those shocks wont work that well with that heavy of a spring you would be better off with the Afco 1020s I think thats the right one for the front. If your realy wanting cop shocks though I have a set for the front I only used for a bout 2 weeks. They are monroe's Give them to you for half price. The wire diameter should be 1/2 or 5/8.
          Turbo, I know Afco 1020s are good, your tan GM handled great with them - problem is they are $55+ each, and I don't have that money right now, plus I can't wait for shippings and stuff like that cause at the moment I have no shocks whatsoever in the front. Your Monroes, are they the gas MAG-RV ones? Shoot me a PM with the price please.
            P/N is 5801ST Perty shure they are Monroe. 20 for both Gets you going untill you can shoot for better.
              Ok, I'll take them, are you gonna be home tonight at like 9:30-ish?
                If I want it lower, would I need to order custom springs?
                  No. Mine dropped 1-1/8" With TruCoil 925lb/in 12" springs. No modding at all, a direct swap. Working on a set of rears right now, though yours is a bit different in the rear than mine.
                    call a bit before just in case. Will be around Sat morning but off to pick up anothe CV and two engines in the afternoon If I have a driver that is.
                      Blaze- I'm talking 3". My springs are so blown right now that it already sits at least 1.5" lower than my dad's '90.
                        Well, I went to Dave's tonight, got the shocks in - what a difference in the handling, flew in some sharp right turn one the way back at about 40-45mph and the car didn't even lean much. I can only imagine how it's gonna be when I replace the fucked up lower ball joints.
                          Measure it for me Freshmeat. Measuring is the best comparison, because I had old factory springs as well. So we may be working from the same point of origin. Meaning these springs actually drop over 2".
                            are you guys gonna get your alignment checked? if so ask them how much it was off, if any.
                              i'll measure superlincs ride height if u mangs want........it got stockreplacement springs last yr
                              scott
