OK gonna need some info
    On how to do a budget 460 hot rod. Stock car block.
    Max Investment
    2000 bucks TOTAL!!!
    (That means 1800 after the purhase!)
    First stuff,
    Disassembly, cleaning, hot tank and magnaflux. This should much about 400 or less.
    Next?
    2008 Mercury Grand Marquis GS Bone Stock
    The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
    You will need a bigger wallet for what you just asked for.
    Southern Fried Florida Cracker
    Not Your Average 450 Horsepower Grandma Car.
    2002, 2003, & 2006 Team Moroso Member
      big block and low budget dont go together......... build a 351w.
        :stupid:
        Best bet would be to find one of the desirable factory engines anyway, something with the good heads and such. I know not this information, someone else would tho.
          Dosen't matter, both blocks were garbage. One was locked up (much to the SURPRISE of the slavage yard, and the other had a crack that Ray Charles could have seen!)
          FUck how much can I get out of a stout 302?
            Go 351. Better torque.
              Yeah, a 351 can be had for a pretty reasonable price too. Extremely common in trucks. Its been heard of to do 400 hp from a 302 with a stock cam, but its certainly not cheap. I've seen Explorer motors for sale for under $500 used.
                A 351 is a stronger block anyway. Plus you can stroke one to 414 or so stock. All the torque of a mild big block and the wieght of a small block. Plus there are much fewer fitment problems, most of the stuff Ford has already done for you.
                  Ive got a 351w you can have come and get it.
                  1989 Grand Marquis LS
                    SP, what's the block code on that.
                    If he doesn't want it, I do.
                      Put me in line for it too, if nobody else says so.
