PDA
View Full Version : {CARB-SWAP}Coil resistor help
grandpaslincoln
12-29-2004, 10:44 PM
I bought a points coil for my car today, for the new distributor I got. But, I forgot to get a resistor for it. I was online, on partsamerica.com, and it has listings for ballast resistors, and coil resistors. Which one do I need?
This is the one I was looking at, but is that really a resistor? I am proficient with electronics, and I do not see a resistor anywhere in there. Is this what I need?
http://www.partsamerica.com/product_images/img/NIE/ICR22.jpg
Once I do get it, it must go between the power from the bat, and the positive terminal on the coil, right?
I should know this stuff, but for some reason, I don't. Oh well, I guess thats what GMN is for anyway.
Thanks guys!
Lincolnmania
12-30-2004, 09:50 PM
that is a resistor wire. you could use that if the price isnt too bad........i used a ceramic block resistor on my 84 crown vic..........damm if i remember how to hook it up.......maybe it will come to me later
scott
grandpaslincoln
12-30-2004, 09:55 PM
That one is around $7 at partsamerica.com
I think it needs to go between the + on the coil, and the wire from the ignition.
Mercracer
12-31-2004, 06:34 AM
Your factory wire harness uses a resistor already.
Points suck dude. I would rethink using a points distributor. For about the same price, you can get a Duraspark II distributor. Harness and box should be easy to find in a bone yard.
If you are bent on keeping your points distributor, and plan on future upgrades or doing any drag racing, pick up a used 6AL and just use the distributor as a trigger, as the points will last virtually forever. Another choice is to get an Igniter module to replace your points.
My first cars used points. I took my drivers' test in a '73 Mustang fastback. I know that you can run points, but there is no reason to any more.
grandpaslincoln
12-31-2004, 05:12 PM
Points rock, electronic ignition sucks balls. :D
I did a carb conversion on my '85 LTC, and decided to use a points distributor and all that good shit.
In all my experience, I have had no problems with vehicles that use points ignition systems. I have, however have had nothing but problems with vehicles with electronic ignition systems.
Mercracer
01-01-2005, 11:50 AM
You have to tell me this story man.
What problems have you had with an electronic ignition system?
grandpaslincoln
01-01-2005, 08:28 PM
theres no story to tell. I had a car with DIS, and the Coil pack thing took a shit. Cost a fortune to fix. How much does it cost to replace points on a distributor? $2.50.
How much to replace an engine computer? might as well buy a new car.
How much is an EEC-IV ignition coil? $50
TFI module? $40?
How much to replace a points coil? $15.
The point is:
Points are simple and cheap. There is one wire to hook up, no sensors, no fucking computers, no bullshit.
Mercracer
01-01-2005, 09:17 PM
$2.50 for points? You aren't supposed to shop at the dollar store for car parts. :yay:
If you are doing a conversion from EEC to something else, you only have to buy a Duraspark distributor once which is about the same price as a points distributor, and you should only have to by a Duraspark II module once. No regular internal maintenance ever.
Points are subject to burning out on a regular basis. They are a wear part. Performance suffers as points wear and readjustment becomes necessary.
I get your point although I do not agree with it. I do agree that FI and EEC systems can be more expensive when parts fail. For a daily driver, I will take the EEC and FI over a carb and points any day.
grandpaslincoln
01-01-2005, 11:08 PM
Dollar store? WHY YOUS!!!!!
I also see your point, and I don't have anything against FI in particular, its just a lot of shit to deal with is all.
85crownHPP
01-02-2005, 08:23 PM
dude! if you can drum up 100 bucks one of these will hopfully solve your problems.
http://images.andale.com/f2/130/105/11070907/1082837156330_heidist289302a.jpg
Im willing to donate 10 bucks for real. 4 more of us do it and you're halfway there.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33690&item=7945020734&rd=1&ssPageName=WDVW
grandpaslincoln
01-03-2005, 12:09 AM
I have already bought a brand new Points distributor. I paid $60 for it, and I don't see the point in returning it, then spending $100 dollars on that one. I'll just have to wait and see what happens.
Thanks though man for the offer.
Paul_
01-03-2005, 02:37 PM
i'd donate 10 bux too if needed
Ifixyawata
01-04-2005, 01:13 AM
Hey, let's convert back to flat-heads and run leaded gas!
I can't say much, I'm converting my '85 CFI T-bird back to a carb, but at least it's a 4-barrel. I likes my gas mileage. You won't catch me taking the SEFI off of my Grand Marquis ever, though. There's no comparing to the smoothness.
Grand Marquis GT
01-04-2005, 07:33 AM
Dont give me any ideas, eh?
Cowman
01-06-2005, 11:09 PM
I have to side with the others, points suck. I'd go with another option. Duraspark II. It's not the thin film TFI thingy that is prone to failure. Duraspark II has a module that sits on the fender well. It's basically not much more than a solid state replacement for points and it's VERY reliable.
SleepyMerc
01-09-2005, 10:00 AM
When I fix a problem on an EFI car I just feel overwhelming relief. It's mostly a matter of guessing which part to replace.
When you tune a point set and a carb and get it running right there's sense of accomplishment that I just don't get from electronics. Most guys just don't get how the carb, points, and advance curve all have to work together.
The thing is it's fun when you want to do it but a pain in the ass when you HAVE to do it.
EFI is more expensive but it is easier to get the smooth flat torque curve and driveability and mileage compared to carbs. Set it and forget it!
