I live in Walden and work out of Lyndonville. It seems like VT has the cheese business wrapped up haha
Wagon Dual Exhaust?
Maybe a junk yard?
Originally posted by Pretty much broke View PostI live in Walden and work out of Lyndonville. It seems like VT has the cheese business wrapped up haha
Not much here haha. Which brings me to my next question unfortunately. In the process of taking off the intake manifold for valve cover gaskets I broke the white bit on the TV cable. The cable, spring, grommet, and clips are all still fine, but the white bit is broken. Am I screwed here or do you think I could make this work? Because if I can't the daily driver is gonna be down for the count until I locate that unicorn of a part. thanks!Current cars:
1989 Crown Victoria LTD wagon, 94,872 miles
1990 Volvo 240 DL 318,513 miles
I've tried foreign cars but I always come back to Ford in the end.
the white bit? You mean the clip that holds the rod in place on the cable? Or do you mean the center bit around the cable? that part around the cable isn't a big deal. The clip bit in the block section that holds it in place is though. Here's the fix I did on my car. I only have about half of that clip left (it still works, but just in case, I have this sliced up bit of hose and a small hose clamp on it.
oh... mine is like that too... ignore it. Just mount it back and go. That's not an important part. As long as all the black parts and that white pin in the block are good, it's fine.
yes. Same as mine. Mine works fine when attached. That broke on mine too the first time I ever touched it. That was 5 years ago. No issues since.
Thanks a ton for the info on that, I was getting nervous. I think I bit off more than I could chew for the valve cover gasket job though. While I did successfully finish it finding where the vacuum lines went and where they came from almost drove me mad. Ran AWFUL on first startup only to find I forgot to re attach the MAP sensor hose. There are still 1 or 2 disconnected hoses but I'm pretty sure they're emmissions stuff. I guess going from working on volvo 4 bangers from the stone age to a v8 may not have been the best idea.Current cars:
I was wondering the same to be honest. It would give it a good look. And my rear window for the trunk door doesn't go down anyway. So no worries about updraft.Current cars:
the problem with that is you pretty much need to put a 180 bend and then a 90 to get them out before the tires as the muffler exits about at the front edge of the wheel.
Back again haha. I really have no idea what's up this time, after doing the plugs and VCG's and putting everything back together it purrs at idle and will rev up really nicely in neutral or park. But when under load it surges and bucks when accelerating or if I'm on the gas at all. I know these things are prone to vacuum leaks but I don't think a vacuum leak would cause that. There is one hose that I haven't found a home for yet and I'm wondering if its that. But any ideas? ThanksCurrent cars:
Maybe photos would help???
