I think so. E0AZ-7F330-A is the listing for the TV rod cars. I can't actually find anything for the cable cars. My master parts manual pre-dates the bronze bushing service part I think.
To much fuel
An update, the bushing was right, the car seem to run ok, but i had it stall on me slowing down to go around a corner at about 10-15mph off the gas and brake, i think i fixed a big vacuum leak with the headlights, i switch a green and blue line around at this wierd box under the dash has 3 lines going in( green, white and blue) white being the source.
Kishy probably knows more about the headlight controls on a Mark VI than anyone here. He's done some writups on the various bits of the system.86 Lincoln Town Car (Galactica).
I'd carb swap it before I put a 4.6 in, but i have no interest in the modular engine. I'm also not a carb guy so that says a lot.86 Lincoln Town Car (Galactica).
Originally posted by 82EmilioPucci View PostHas anyone on here attempted a 4.6 swap in one of these, I've been thinking about it.'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
Search for "modbox"
That job looks like something id be down to tackle, thats is the 4.6 swap, not that frame stuff! Is there a year of 4.6 i should say away from, ive heard early ones have valve seals and something about 04s, and i want the obd 2 as the guy who did this before, i like the plug and play stuff, would 99 to 03 be the best range?
‘01+ would be best since they feature the Performance Improved cylinder heads. You could use a ‘96-‘00 engine, but it wouldn’t be as snappy in stock form. The ‘91-‘95 engines are the ones known to have the oil burning issues with the original valve stems.
If you’re going the 4.6, I’d just look for the lowest mile one you can get that meets your criteria. You’d also need to grab the whole wiring harness for the engine and transmission from the donor car.
My Cars:
'05+ is drive by wire.
My Cars:
