Okay IDK if ya'll Remember me with that 96 Marquis?? Black Beat the F up? High Miles???
Well Anyways I just got around to cleaning up the engine bay and noticed a big problem while changing the plug wires.
In the back "right hand" cylinder I found coolant in the spark plug bay area, there was also SOME dampness around the valve cover.
I am loosing coolant it seems to get really hot while the a/c is on BUT that's because the RAD fan turns off and the electrical fan is the only one to run while ac is on. No smoke other then oil once in a while from the valve stem seals, BTW how hard would it be to fix those up this car..??.. So i thought this out, I still like the car allot, and want to keep it, it's now hot "literally" at 312,000 Miles starts chipper and crisp...no grinding no broken O\D gear Just would like to know if i should be driving it or put her off to the side while I fix her up and buy the Cadillac next door?
Let me know your advice, THANKS!
