Cruise control don't work at all I checked my fuses and relays
Cruise control problem
Cruse control module by brake booster???
+1 check the vacuum lines to the cruise servo if they still have vacuum lines going to them on the later models. Either the cruise servo, the wheel buttons, or the cruise module has issues if fuses are good and it doesn't do anything. Could be a dirty clock spring. Does yours have the "cruise" light on the instrument cluster when you turn the system on? If so, try moving the steering wheel to different positions and pressing ON. If it works in other positions, you probably just need to clean the clock spring... which requires pulling the steering wheel off. Disconnect the battery for at least 1 minute before touching the screws to remove the bomb (airbag) so it doesn't blow up in your face. Be sure to re-attach the bomb before reconnecting the battery for the same reason.
