Hey all,
I'm wondering if anyone has had bad pinging under heavy load while using regular gasoline. I filled up with regular (was using mid-grade for a few months) just the other week, and under load, the engine would ping and felt weak when at operating temperature. I put in premium today just to see if it would make a difference, and once it was warmed up, decided to go at WOT. Heard no pinging and the pull felt strong as it moved up to 60 MPH.
I never noticed pinging or weakness on mid-grade either, but regular seems to burn poorly. I also found burning regular used to irritate my downstream O2 sensors when they were going and would often set off an inefficiency code (hasn't happened since they were replaced, however). I've run injector cleaner in it before and it's even been Seafoamed previously, so I'm doubting carbon build up. The car just seems to run properly on mid-grade or higher.
Anyone else experienced something similar?
