Can you even use the PI inkate on the NPI heads???
Port and Polish
We can port the non PI heads to match the PI intake. Ported non PI heads will out flow ported PI heads. The expence of PI or other aftermarket cams are not realy worth the cost on ported heads. Increasing the vale size works better. We also have our own valve design designed by us which flow better than the aftermarket ones. They are also a specal size flownd to flow better in the combustion chamber.Scars are tatoos of the fearless
I would go to PI's but im worried about...
Mainly making the trottle cable work like it should when I move the intake forward and to the right...EGR shit vacum line etc
And its a 92' REP block I don't think PI heads will fit itLast edited by Grandmarchris; 02-02-2007, 02:40 AM.R.I.P Linsey Nelson
Originally posted by MeanVic84Chocolate Rain. Some stay dry and others feel the pain.
While the heads are off have the valve seats ground down so you can run PI cams in the nPI heads.
Modular head porting is no simple matter, don't cheap out.
You can use a PI intake on the nPI heads. Use PI gaskets, with a dab of RTV in the small corner of the front water jacket.
This makes for 2 dabs of RTV - vs 8 beads of RTV (1 on each airport) trying to use nPI gaskets for the PI intake swap.
Might as well go all-out and convert the car to OBDII as well.
It would prove more cost-effective to just find a donor 01-02 CV/GM and nab the wiring, engine, PCM, etc.-My Homepage, Panther info & FAQs-
My Mint 96' Mercury Grand Marquis LSE -
Modifications
Click My Merc for more Pics!
All the Mod heads run about the same to port 600.00. Some have more material to remove than others. With options they can run up to around 1000.00. The 4 valves start around 1000.00 and go up with options.
I sugest port matching Non PI heads to the PI intake or there is a severe port mismatch. The PI intake is tuned to aroud 1000 RPM higer peak.Scars are tatoos of the fearless
Im debating between 4 options
Running a PI intake with ported NPI heads
Running PI everything
Running with an edelbrock PI intake only
Converting it to carb and running a barry grant speed demon or holley 575 cfm carbR.I.P Linsey Nelson
Converting it to carb and running a barry grant speed demon or holley 575 cfm carbScars are tatoos of the fearless
