big front brakes are easy for you sniper......you already have the proper spindles.......spindles r the same 96-02
heres a list of what you need.
16" wheels (at least on the front)
1998-2002 wheel bearings
1998-2002 brake rotors (12.5" )
1998-2002 brake calipers (difference they are 2 piston calipers rather than a single piston)
1998-2002 caliper brackets
1998-2002 brake hoses
all in all the swap on your car should only take an afternoon......braking is much improved
scott
Thank you SCOTT for the prompt respond but I have a doubt ¿ Why the wheel bearings of 1998/2002?
ATT.SNIPER 308. :nightrid:
MERC75-INTERCEPTOR, BORN IN 2003,DIED IN SEP/21/2010 AT 9:55AM AT THE SORT AHE OF 8 YEARS PROTECTING HIS OWNER TO DIE
96-02 cars have the same spindles, but for some reason they changed the hub bearing also in 1998 for the larger brakes. check the part numbers betw a 97 to a 98 hub bearing and they are a different part number......i do not know what exactly the difference is sorry
scott
