Does the ABS system have a temperature sensor of some sort that measures the brake rotor temps? I have noticed that since the EBC upgrade, my brake rotors heat up quite a bit. After being stuck in "stop & go" traffic on my commute home; when I leave the GSP, the car hesitates a bit when I accelerate. The coolant temp gauge says it's okay (below the half-way line); but I will put my Actron scanner on it to get the actual temps. Also, when I get out of the car, I can smell the brakes cooking. This is during the spring and summer days; not during the winter. This only happened after switching to the EBC rotors and pads. So, does the ABS system detect the hot rotors and pull fuel and timing to save the brakes?
Hot Brakes!!!
No temp sensor on the brakes that I ever heard of.
Do the front rotors and pads match the rear?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
- Likes 1
sounds like the brakes are dragging to me. Bad caliper, crusty pins, something like that. Doesn't really matter what pads are installed, the brakes should not be hot when not being used.
and no there is no sensor. The system just isn't that advanced.86 Lincoln Town Car (Galactica).
- Likes 1
Originally posted by gadget73 View Postsounds like the brakes are dragging to me. Bad caliper, crusty pins, something like that. Doesn't really matter what pads are installed, the brakes should not be hot when not being used.
- Likes 1
Pins sticking would be my first guess. Also, if those are factory brake hoses to the calipers then I would replace at least both front ones. At this age they could be collapsing internally and causing the caliper to stick.These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
- Likes 1
+1 on the hoses as well. Forgot about those.....agree also on the pins. Has the car sat for a while after the repair? Could account for the issue.Last edited by friskyfrankie; 04-05-2023, 08:34 AM.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by packman View PostStock hoses. I will get those changed out. Might be a good time to consider fitting sizes and such for the bigger brake upgrade anyways.What I Own: 1993 Mercury Grand Marquis GS
- Likes 1
easy way to check if its the hose, when the brakes drag, crack the bleeder loose and see if it spits fluid and stops dragging. If neither happens, its not the hose
though if they are 20 years old they're due for replacement anyway86 Lincoln Town Car (Galactica).
- Likes 1
Are those new brakes ceramics? Ceramic pads are like insulators too, they will move less heat to the pad backing plates and caliper mounts, leaving the heat in the rotors. Friction creates heat, and that heat will seek a path to relief .... either through the rotors or through the pads.
No ... I'm not arguing with you ... I'm just explaining why I'm right ...
Now go ... and whatever you do ... have a safe trip!
Semi-metallic. I replaced all the hoses and rear calipers last week. It seems to have alleviated the dragging. I am waiting for the GT500 rotors to come in, so I can install the big brakes up front. That should be the more permanent solution to this problem.
