Looking at a whole rear differential for $50. Its a 3.08 8.8 inch ford which im pretty sure is whats in my 97 grand marquis? I was told it would fit if i had a 31 spline axel it would be a perfect fit. Do i, and if not would it be easy to buy some for not a whole lot like maybe out of a junk yard and rig it up still with my air suspension/disc breaks?
Rear end noob needs help
Its a 28 spline. There are many many variations of the Ford 8.8. You need to have one out of a panther chassis car from 83-97 or it wont fit. Ideally you want 92-97 so its an exact replacement.86 Lincoln Town Car (Galactica).
Ford used 8.8's in anything rwd that could come with a V-8. Fox chassis, Exploders, pick-ups, you name it. The spline count only matters if you're swapping internals. It's the externals (suspension arm mounts, hub-to-hub dimension, stuff like that) that you need to get right. Easiest way to do that is to make sure it's out of a Panther chassis.'84 Grand Marquis
Damn thing just keeps runnin'!
"Half the harm that is done in this world is due to people who want to feel important." T.S. Elliot
If you're serious, you need to find out what a transmission shop will charge for the work. This isn't really for a noob to do. You will need about $300 in specialty tool just for openers.'84 Grand Marquis
Yes, you can change the rear gears.
yes, you can change the carrier to make it a traction lock
Yes, you really ought to pay someone who knows how to do this work.
Be aware that the outer axle bearings ought to be changed, and the outer seals must be changed when you do this. Its also very possible that the axles themselves need to be replaced. I'd probably also spring for new pinion bearing and seals since its going to be out. The inner bearings you can also change but they're likely OK.86 Lincoln Town Car (Galactica).
I had to have the rear axle on my 88 rebuilt.. the only good bearing was the divers side wheel bearing. the passenger side was so bad it etched the axle (spacer bearing used) and the carriage bearings were about like gravel and the pinion bearing was shot to hell too. Wish I had the $$$ for the powertrax locker when I did that, but oh well... next time.
