shorter/longer springs is the best way. There's also spring spacers out there. You will of course need an alignment for camber/caster when doing such mods.
Then you can adjust the RAS level sensor (Rear Air Suspension) to match it.
You're probably looking at $200 or so for front springs.
You could try raising the ass end a bit to give it a bit of a rake just for shits and giggles. It wouldn't cost you anything, and you might even notice a bit of aerodynamic benefit.
