yeah they go back and forth, but its not a full rotation by any stretch. The actual needle itself might make a full roll but the inner shaft relative to the outer cup doesn't move very much.
Curious Vibration While Coasting
Originally posted by DerekTheGreat View PostI watched Eric The Car Guy rebuild an 8.8 and said F that. You guys that have the patience for that, good on ya.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by IPreferDIY View PostU-joint related play and clunking aren't issues. I'm getting a bit of funny vibration during the transition from powered to coasting movement, but only at highway speed. I would guess that the one axis that had freer movement (but without slop) is the culprit, and I'll find out soon enough; but in the absence of an emergency, I’m not climbing under my car again until the weather warms up. What’s wrong with wanting to learn how things work in the meantime? I’d love to be able to spend some more time learning more about the Riemann hypothesis, but there doesn’t seem to be much chance of that being productive until my eyes are finally fixed.
I turns out that the hybrid U-joints aren't astronomically priced like I thought they would be (as a 'specialty part'), so I'll probably go for whatever decent CVPI aluminum driveshaft comes my way rather than hope for an older one that uses 1330s. I should be able to get price-matching on Spicers (at least the 1330s) at a local place. I would want to be able to use the driveshaft in something else when my current car reaches the end of its life, so I won't cheap out on those.
I got a 1330-1350 convo joint for like under $20 at the local NAPA, tho they do give me a bit of discount there so idk what retail actually is on it. Made in Japan too, I'll take that over China or India any day!The ones who accomplish true greatness, are the foolish who keep pressing onward.
Oh starting from scratch any gear setup is a bitch. But the nice thing about Ford axles (both the 8.8 and the larger 10.25 and 10.5) is that they are VERY consistent in their tolerances, meaning if you are installing factory gears from another axle just keep the pinion depth shim with its respective pinion and the carrier bearings preload spacers with the respective axle and 9 times out of 10 you'll get both backlash and patter right on. If you're just rebuilding an axle with new bearings it's even easier, just pull old junk out/off and press new stuff in/on, unless you're very unlucky you'll be good to go. I've run into some that have the carrier is loose even with new bearings, those you gotta start messing with the shim stacks for the carrier preload and gears backlash, but even so at least you're not dicking with the pinion depth - I had to redo all of those specs on my D80 cause the bearings were worn but still in great shape (if that makes any sense), that was anything but fun of a job.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Oh wow, I didn't know that. From all the frustration Eric had I thought that was just common. I wondered if you could just reuse the shims when changing gear sets. But also, isn't the contact pattern of the gears affected by the shims and such?1985 LTD Crown Victoria - SOLD
Yes contact pattern is directly affected by the shims. That is why you keep the pinion shim with the pinion, and the housing/carrier spacers with the housing. The shims and spacers are not a wear item, the bearings are - replace your bearings and you're back to factory specs, maybe a tiny bit looser cause of gears being worn out, but they really shouldn't wear any noticeable amount. Most of the time even with a gear swap as long as you're using factory gears and your "new" pinion still has a shim on it things go smoothly with little to no special work needed. I do not watch Eric the Car Guy, or anything else on youtube for that matter, so I don't know what issues he was having - but I have run into IIRC two axles where new bearings with the factory shims still ended up bit too loose on the carrier bearings preload for my liking, they were in spec as far as backlash goes but the bearing preload just didn't give me that warm and fuzzy feeling inside. And once you're messing with the side spacers to obtain proper carrier bearing preload, you can use that opportunity to shift the carrier around till you get a better backlash and gear contact pattern.The ones who accomplish true greatness, are the foolish who keep pressing onward.
If aftermarket gears or carriers are in play, that may change it. OE Ford parts are made pretty consistent, but the China-made gears may not be so precise.
I want to say one of the shims on my Towncar was damaged for some reason. Scott replaced it with one out of his drawer of parts that was the same size and it all went together fine.Last edited by gadget73; 02-17-2017, 05:33 PM.86 Lincoln Town Car (Galactica).
Just figures I was the 1 in 10 that didn't like the result with a new Ford 31sp carrier and gears with the stock shims. Ended up changing pinion depth and backlash. I also wasn't talented enough to stack aftermarket carrier shims. Anyone that can do that gets my admiration. Luckily one of the local dealers had the factory ones I needed in stock. I vowed to never take that on again myself. Then again, don't know if I would trust an unknown person not to say good enough and just slap it together.sigpic
89 LTC 429>557 Cobrajet stroker
13 F-150 XLT 6.2 l
"If I could separate what's real from what I've been dreaming I could live to fight another day"
Setting gears up on any mechanical thing is not really that hard, you just have to follow the procedure and use the right tools. Stuff using shims is more tedious than hard, but it can get hard if it comes apart in a retarded manner.86 Lincoln Town Car (Galactica).
Yeah, it's mostly annoying than hard really. Well it gets hard on you when you're working with something that has a ring gear about a foot in diameter, and it's exponentially worse as the size increases. But yeah, patience is the main ingredient, Prussian blue (for used gears) or yellow paste (for new gears) would be the close second. Add limited slip internal shimming for extra funThe ones who accomplish true greatness, are the foolish who keep pressing onward.
I got one, but it's low mileage (for a commercial-grade vehicle) and works extremely well so I have no reason to dive into it. I do recall someone on Pirate doing a rebuild on one of those with good pictures and explanations, gotta see if I either bookmarked it or PDF-ed it... Why, you thinking of putting one in your Towncar?The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by His Royal Ghostliness View Post... Consider this for your vibration - Spicer joints have a plastic thrust washer between the cap and the face of the trunion, if that washer is worn out it will allow the shaft to slide sideways across the U-joint some, which will certainly cause vibrations at some driving conditions or others. ...
You might be having some lubrication issues there. The plastic thrust washers generally don't give a hoot about ambient temperature, but the grease there sure does. One way to find this out, pop the U-joints apart and have a look-see.The ones who accomplish true greatness, are the foolish who keep pressing onward.
