several guys on MM.net figured out how to run 14" Mustang rotors on the newer panther chassis spindles.
Basically, you need to have the 98-2002 big brakes already on your car.
all you do is buy a machined adapter that allows Corvette C5 front calipers and brackets to bolt to the spindle along with a 14" rotor from a mustang GT500. Marty at MO's speed shop keeps the adpaters in stock.
THIS WILL REQUIRE 18" WHEELS OR LARGER
here is the original post on MM.net with the parts list --> https://www.mercurymarauder.net/foru...ad.php?t=94024
