C-Pillar window removal 97 CV
Since it's bolted down from the inside, you'll have to remove the C pillar panel... which requires removing the back seat IIRC. Then you can remove the nuts and then use a SHARP putty knife (or other implement of slicing that will fit in there) to cut all the glue. I think it uses the same adhesive as windshields. Can probably get away with RTV, but the windshield stuff will definitely fit the bill.
