Hi I've got a weird sort of 'servo motor' noise coming from somewhere behind the light switch area of the dash. It sounds a little like a vent flap motor except that it goes off at random , nothing seems to happen other than the noise but it obviously shouldnt be happening and its driving me nuts . I do get a 24/25 code on my ETACS but didnt think that the blend door problem was in this area. Any ideas guys ?
dashboard noise drivers side ( ETACS maybe?)
is this on the car in your avatar? and just what year/model is it?
if it's got the auto brake release, check the vacuum line going to it and make sure it's fully connected. You may also have a vacuum leak under the hood that's allowing said brake release to actuate (bleed out under low/no vacuum and then retract with good vacuum).
hi , its a 1996 Grand marquis and it does have the auto brake release, i'll check it out , thanks, I love the car 'coz its just so different over here in the UK ! plus its got such a nice smooth running engine compared to my subaru legacy
