I am swapping in a 200A alternator to my 2002. I am investigating the use of a 2004 PCM just to control the alternator. Anyone know if a PCM can be used for controls without being wired to a running engine? I would mount it out of the way and only run absolutely necessary wires to the pigtail. The only write-up I have seen is this one linked below which uses an aftermarket controller which does not change with vehicle system load.
200A Alternator retrofit
I doubt it since the PCM would need to know load values I would think. But it should be easy enough to plug in a 2004 PCM and load it with the 2002's tune at a tuner shop.
Originally posted by slymer View PostI doubt it since the PCM would need to know load values I would think. But it should be easy enough to plug in a 2004 PCM and load it with the 2002's tune at a tuner shop.
