I can feel that the A/C is getting cold, but the blower has stopped working. I checked the 40 Amp fuse and it's good. Also checked the blower relay. It's also good. So my next step was to change out the motor, but when I pull off the wiring harness and stick the probes of my multimeter in there I get zero voltage. I'm just wondering if you guys have any suggestions as to why there is no power at the harness when I have the A/C turned on. Don't want to go through the trouble of swapping out the blower motor until I'm sure that's actually the problem.
Thanks in advance for your help.
2003 Merc Grand Marquis
Automatic thermostat controller.
