How Do You Remove an Alternator Pulley?
    Title is self explanatory, but the car I need to service isn't a Panther, but has a 4.6 and uses a 3G alternator.
    My friend has a 2000 Expedition. It uses a 8 rib pulley. I have a spare 3G alternator that he can have, but it has the 7 rib pulley, so I need to swap them. Would I be able to loosen the bolt by leaving the failed alternator on the truck with the serpentine belt in place and attempting to go at it with a socket and breaker bar?
    My Cars:
    Not likely. I've been able to get them loose with an impact before if it spins it quick enough before the belt slips. Otherwise you'd have to find a way to jam the alt. so it won't turn while you use a socket/bar.
      I'd be worried about the belt turning the crankshaft in the wrong direction. Will the belt always slip before then? Or does it have a reverse thread?
        Impact gun in one hand and a leather glove on the hand holding the pulley. Will spin the nut off within 10 clicks usually. At least my electric one from HF does the job like a champ.
          Don't even need the leather glove usually, bare hands work just fine for this. And yes, impact wrench would be the tool of choice for this.
            I guess we will need to go bother someone for an impact wrench. I don't have one, and I don't think he does either.
            Thanks guys.
            My Cars:
              lol sounds dangerous bare hand lol
                Eh, it's only dangerous if you go about it the wrong way - clamp the bitch down like you mean business, but at the same time be gentle with the impacts, and she'll do what you want her to do no problem
                  Well I was mistaken on the year. It was a 2002 Expedition. I don't know why I was seeing things about 8 rib pulleys since when I got the hood open, it was a 6 rib 130 amp 3G, just like any '92.5-'97 Panther. The 90 amp 3G spare went on without issue and is charging the truck just fine. My friend still plans on getting a new alternator for reliability purposes since the one we swapped out was a remanufactured Motorcraft one that only had around 50-60K.
                  My Cars:
                    So you're running a 7 rib alternator with a 6 rib belt? That works fine, as long as you get the empty rib in the right place.
                      Yep. This is the same 90 amp alternator I was using on my car. I set the belt closest towards the alternator and the belt stays where it belongs. Works just like it did on my car and should be just fine until the new 130 amp arrives from RockAuto.
                      I wouldn't worry about the belt skipping unless the tensioner or belt were shot.
                      My Cars:
                        It won't skip, but if you have it a groove off it'll slowly shred the belt to bits.
                          I work for Peprilleyadvanapazone, and I have swapped pulleys for customers many times, even if they weren't buying anything, because it's good service and tends to encourage future business. Your local location may do it for you. I would.
                          Back in the saddle again!
                          2004 Crown Victoria Police Interceptor in Unimaginative Bureaucratic Brown
                          Bone stock... for now.
                            This. I did this when I worked at Advance. The electric impact we had was handy!
