Hello I own a 1997 Grand Marquis LS and I'm wanting to install an aftermarket stereo this car has no antenna Jack for the aftermarket radio and I believe I need to put in an antenna adapter how do I install this Antenna adapter thank you for any help or ideas
Aftermarket radio antennw
The stock radio should have some kind of antenna input. Even the cars with the antenna on the rear glass have an antenna connector. If the aftermarket radio has no jack for the antenna connector, it should have with it, or available as a separate purchase, an adapter for connecting the stock antenna connector. If you don't see the antenna cord, dig around for a coax looking wire back behind the radio and see if it just fell down.
Also, PERIODS. It's not that hard to put a freaking period at the end of a sentence. Even on a phone.
