I just purchased an aftermarket stereo for my 97 Marquis and I got the wiring harnesses that snap into the factory connectors and I hooked up everything according to color and I'm not getting any sound out of the radio I don't know if it's because the head unit is in the trunk but the wiring harnesses should correspond to the new colors on the new radio anybody has any answers or ideas I would appreciate it also how does the antenna hook up on the new unit if there is no cable for the antenna since the antenna is a window antenna
Aftermarket stereo
If yours has no antenna cable, it'll be plugged into the stuff in the trunk. There should be a bypass harness that goes in the trunk to eliminate that, and you'll need an antenna extension cable to get the antenna up to the front.86 Lincoln Town Car (Galactica).
As for the wire colors... If you're plugging into the factory harnesses with a wiring kit... the colors should line up with the radio's harness and you just need to match that up. Barring color matching, you should have a wiring diagram on the harness kit (or tags/printing on the wires themselves - magnifying glass may be required) and in the radio's manual and then you can match it up that way.
