1994 CVPI Speedo not working
    Hi all, recently replaced the odometer gears on my ‘94. Put everything together and the odometer now works, however, the speedo stopped working. To test I purchased another CVPI speedo off eBay, installed it into my car and the speedo worked.
    I think it has to do with popping the MPH needle off the speedo. Even tho I was super careful popping it off, it seems to effect the operation. As when I popped the needle of the new speedo I purchased off eBay and put it back on, the speedometer stopped working on that one as well. Anyone run into similar issues ??
    Appreciate any tips
    Check the connections internally to the speedo going to the motor for the speedo. Something may have been knocked loose in the process.
      Thanks sly, I’ll double check. Ive heard the speedometer motor is super sensitive. Hopefully it’s not damaged but ill take it apart again
