How is everyone? Sorry I haven't been around, dial up won't load anything in the amount of free time I've had recently.
Pulled codes on the '88 today. Surprisingly, got only three codes (down from the 8 or so I had several months ago).
For the KOEO test:
- Code 34 - Insufficient EGR flow/Excessive exhaust back pressure; or EVP voltage above closed limit(SONIC)/PFE sensor voltage high or out of range. (WTF does that mean?)
- Code 51 - ECT sensor fault or open circuit
For the KOER test:
- Code 98 - Computer detected hard fault (EEC in FMEM or Failure Management Effects Mode)
I'm gonna check out the ECT sensor and swap in a spare. I'm open to suggestions on 34 and 98 (which kind of worries me).
Also, pulled the codes on my mom's '87 5.0 Turdbird which has developed a engine missing problem during warm up. Got code 42 - Oxygen Sensor indicating system rich, right side. Oxygen sensor problem?
For the KOEO test:
For the KOER test:
