hi i have an 85 merc 2 door with shorty headers 2.5 exaust with glasspacks going out the side it has all the bark it needs just it has no bite. So i wanted to convert it to efi or carb but what would be easier and could you please explain
whats easier efi or carb
---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
---1985 Grand Marquis 2-door., Fresh 5.0, slick-top, GT40P's, 1.7 RR's, FRPP headers, 3G alt., Weiand Stealth intake, 650 cfm holley, 2.5" side-exit exhaust, Mark 8 elec. fan, 3:55 Posi, Bucket seats, custom center console. My ToyTags: None
fatnasty is doing a CFI to EFI swap but alot go towards the carb, not that hard
who cares about gas milage all i want is more power lol---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
I hear you there, lol...
Here's what you'll need:
4bbl carb (edelcrocks work great, or use a 600 cfm holley)
4bbl intake
1" phenolic spacer (helps with clearance for the linkages)
Lokar TV Cable, 24" throttle cable, and stainless steel bracket
1984-back duraspark II distributor for 302 (must be for flat tappet cam, cast iron gear)
Duraspark module
Cap adaptor for above to use TFI style dist cap
Alternative fuel pump, either a mechanic or stand-a-lone electric
12" length of 3/8" fuel line
There's probably more, but i'll add it later.
More to come.1983 Grand Marquis 2Dr Sedan "Mercules"
Originally posted by Bowman85merc View Postwho cares about gas milage all i want is more power lol
Depends what you're more comfortable with. If you like EFI and don't mind dealing with the wiring, used stock EFI parts are real cheap. If you don't want to deal with all that, carb conversions aren't that hard, but the parts might cost you more if you buy new. You probably will at least have to get some of it from ebay or whatever since most junkyards aren't really gonna have much in the way of carb stuff anymore.
Something else to consider is inspection where you live. Carb is probably going to have a harder time getting through smog checks.86 Lincoln Town Car (Galactica).
Sounds like a sweet car mang. Got Pics?
Like most of the others, I say carb if you don't care about MPG and your local laws are okay with it.1990 Country Squire - weekend cruiser, next project
Originally posted by gadget73 View PostDepends what you're more comfortable with. If you like EFI and don't mind dealing with the wiring, used stock EFI parts are real cheap.
The problem is that you are stuck with a near stock performing engine. By the time you either chip it or start buying aftermarket EFI parts, your bill gets pretty big. Cheap horsepower is definitely easy with a carb.....
i have the rod style so would i still need a new cable for the kick-down and could i just get an hei distLast edited by Bowman85merc; 01-13-2008, 10:01 PM.---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
how do i put a pic on this---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
You can click on the "Go Advanced" button below and add an attachment for a picture.
Some have had success using a modified rod on a carburetor with the typical Ford kickdown provision, but most use the Lokar kit. Can use an HEI-style distributor if you'd like.1990 Country Squire - weekend cruiser, next project
