Is it possible to use the lopo block and rotating assembly with Explorer heads, cam, and intake. And will that combination run good with a Mark 7 computer without mass air?
LOPO/Explorer Mix
It all should work with the stock lopo shortblock. Legend says the lopo converted engines run the best! Also, the 19# injectors/mark 7 ECM are what a couple of people are using with the exploder cam. Seems to work well, I know Thain's runs pretty good.
Just remember, if you've got GT40P heads, you're limited to the FRPP headers, or those retarded looking and restrictive manifold shits the exploders use. Good luck!1983 Grand Marquis 2Dr Sedan "Mercules"
it will work.....as long as you use the explorer or the ho cam
welcome to gmn!
I heard that OEM Fox Mustang headers worked okay with the P heads, but I don't know for sure.
Reguardless, these are supposed to fit http://store.summitracing.com/partde...5&autoview=sku1990 Country Squire - weekend cruiser, next project
Originally posted by Grand_Marquis_GT View PostIt all should work with the stock lopo shortblock. Legend says the lopo converted engines run the best! Also, the 19# injectors/mark 7 ECM are what a couple of people are using with the exploder cam. Seems to work well, I know Thain's runs pretty good.
The P heads have different spark plug angles, so the different headers are needed to actually be able to connect plug wires. There are other headers that work if you use different plug wires and a shorty plug or two, but the proper headers aren't that expensive, and they fit really nicely.86 Lincoln Town Car (Galactica).
just a heads up as i just completed this modification. waggon runs great and has a hell of a lot more power, but i haven't been able to figure out why it's running so rich yet. i'm only getting 9 - 10 mpg, and i've got raw fuel coming out the tailpipes.
so far, no luck in figuring out why...
not saying you shouldn't do it, but when you're dealing with a mishmash of junkyard parts with questionable origin / quality... it can lead to some really frustrating troubleshooting.1986 Ford Contry Squire: HO engine swap, 3G alternator, 3.73 gears, rear air springs, Class III 8000 lb hitch... potential tow rig for my Blazer trail toy??
